houston.. i have problems?
Owskie
current temps for my computer
are
SYS: 33.0C
CPU 46.0C
this is all idle
im using an antec sonata case
which i just cleaned, two 120mm fans, one bring in air, one pushing out
seems like my 3d card doesnt like me either, i get white dotted lines in doom 3
piss on it all
sad thing is.. my temps suck and i want to overclock
cause my system is a
ABIT NF7-S mobo
AMD Athlon 2500+ Barton Core
333 fsb
1 gig of ram corsair dual ddr
ATI 9800 Pro 128 meg
Nothing OC'd
What are your air temps.
Also you need to find you max load temp.
If your air temps are around 30C and you only hit 50C max then you have a little room to play with.
If your air temps are around 10C and you max at 60C then there is probably no way you could get a good overclock without killing something due to heat.
At the moment my MOBO's are running around 40C and CPU'S are up around 60C 100% load Folding.
But the air temps are above 30C.
Luck......... :D
