Hotswap
psx-dude
i'm considering purchasing 2 sata hard drives for a client and putting them into a raid 1 array for redundancy. however, i want the client to be able to remove one of the drives to take home with them nightly without stopping the server. Anyone know of a way to do this? I was thinking of just getting an enclosure but i don't know if that will let me hot swap the drive out. Does anyone know?
Another method would be to have a small server with two drives in a raid 1 array with hotswap instead of a computer, if anyone knows of something like this. Thanks!
for fully supported hotswap Id use SCSI
no ifs ands or buts ;)
considering its a client
OS has problems even if the enclosure\spec doesnt
Win98 version (like a USB flash compact disk drive which is a software executed hotswap) FILE: HotSwap.exe - Hot Swapping IDE or ATAPI CDROM Devices
real SCSI Support hotswap > http://www.t10.org/ftp/t10/document.94/94-230r1.pdf
SATA hotswap (physical) > http://www.lostcircuits.com/advice/sata150/8.shtml
actual SATA implementation has been less than ideal
if you do go that route, extensive testing is inorder
and tattoo this to his forehead > http://www.seagate.com/training/properhandling/munitintro.html
not sure how well that has been implemented
dont have a recommendation offhand for an enclosure
or any info on hotswap under linux
psx-dude said:
well it says hotswap, but that often isnt the case, most removable racks say that
while often you need specific support from the controller to actually implement it
research and test ;)
