i7 920
12gb corsair
NZXT Case 120mmx2 80x2
GTX 260 216
Kingwin 700
Using realtemp with case open:
Stock Heatsink and fan
Idle
CPU - 25
0 - 38
1 - 38
2 - 35
3 - 37
Prime95 after about 10second
CPU - 80
0 - 89
1 - 89
2 - 89
3 - 88
I came to the conclusion that the stock heatsink and thermalpaste is crap, and got a Thermaltake Q Spin. Got that installed and set the fan to high. Used 91% alcohol to clean the CPU.
Min: Max:
0 - 32 89
1 - 31 88
2 - 32 89
3 - 31 87
Read some mixed reviews on that heatsink.
Another discussion board someone mentioned that the temp sensors may be wrong/bad?
Just got a Thermaltight IFX-14 with 2x 120mm fans and will see how that goes tonight.
12gb corsair
GTX 260 216
Kingwin 700
Idle
CPU - 25
0 - 38
1 - 38
2 - 35
3 - 37
CPU - 80
0 - 89
1 - 89
2 - 89
3 - 88
Min: Max:
0 - 32 89
1 - 31 88
2 - 32 89
3 - 31 87
