I got a "Birthday Present" from a friend. Basically, it's an ancient drive bay for IDE drives. It had a 3 gig Seagate drive in it, if that tells you how old it is.
Anyway, the trey can be connected/disconnected pretty easily, and everything connects/disconnects at once. Is this trey safe to use for hot swapping? I can post pictures if requested (thanks ot another birthday present I got).
Man, this trey caused me a lot of anguish. Someone had taken it apart, and disconnected one of the little internal IDE things, then reconnected it, but only lining half of the pins up. So, it didn't work.
Also, this thing is old enough that it doesn't have the 'key pin' missing, so I bent the pin that kept the cable from successfully joining with the trey. Yes, my PC is ghetto... I should post pics, it's pretty bad. Okay, it's 3 am and I'm rambling... Oh, last thing: The trey had a sticker on it saying "Warning: Do not remove while the Windows are running as it may damage the systems"... Since this is pre-XP Pro, does it still apply? The windows...
