Hot Qpack!!
antok86
DOes anybody else that has a Aspire qpack heat up....cuz mine makes my room really hot!!.....i duNO why...everything is running stock....i rear 120mm as an intake wid a filter and then a 80mm side exhausT.......
if you added a 80mm side then try using that one should be the intake and the 120mm should be the exhuast. if that doesnt work, it wont hurt to open up a window and the room door so the air in the room can be circulated too.
haha i have the doOR open already...haha and a ceiling fan...and its hot when i walk out and come back in.......argh....dont really wanna switch the fans if i don have to cuz i have a 120mm filter...to keep the dust out...and not a 80mm. filter
switching the fans will help make the case cooler...as for your room, thats your own fault :)
the way the fans are set up is making the room hot...with out the computer the roomnot hot.....so i guess its the only way
better a hot room than a hot computer. Besides, there is no way the computer is causing that much heat...unless your room is tiny and you get no air flow
