I found it at that price on at least 2 sites.
More expensive and slower than an i7.
It may be hot only because it's $550from Newegg. I'm actually seeing prices in the $500s everywhere.
What makes this processor better than a Q6600 G0 for $160 that can usually clock to 3.6 with ease?
faster and lower power consumption.
id say 3.2Ghz Yorkfield comparable t0 3.6Ghz kenty
Is this worth getting over a Q9550 I might buy which is 50 bucks less?
I thought the easy OC on the q6600's was 3.0GHz. Is there actually a high percentage of these hitting 3.6?
I thought the new Q6600s are not as well made (easy OCable to 3.6) as the old ones.
wow newegg has it for... 349.99
im still debating. Because i know i desperately need to go Quad core. Ive been putting it off for a long time. But i feel going i7 is way to much money. Its not just the CPU, its the 300+ dollar mobo and ram too... when i can spend it on a new video card or ram for my current LGA775... i think i might jump on these when they drop more. they initial drop is always higher. ill give it another 2-3 weeks...
If I were you (and if you need 45nm quad now), I'd just op for the Q9550 and use the extra $50+ to upgrade your GPU. Yeah, you only get 8.5x with the Q9550, but oh noes, I guess you "only" have a 3.8Ghz quad at 445FSB instead of 4GHz.
*and since you aren't currently on a 45nm dual, getting a higher clocked quad is already plenty improvement.
