Hot-plugging an SATA drive?
djnes
Has anyone ever tried plugging in an internal SATA drive while the system is up and running? I know on some AMD chipsets, the SATA drives showed up as hot-swappable, but I am using an Intel 915 chipset board. If not, I'll just wait until my lunch break when I can shut down the machine and add it in.
I would check out the mobo's documentation. I know a lot of server boards support SATA hotswap, and I think my old crappy chaintech mobo did too, but that was on a ULi chipset.
I believe hot swap is part of the SATAII specification so if your motherboard supports SATAII it will work, but I'm not positive. :confused:
Not sure on an Intel system, but I would wait to turn off the rig to be on the safe side.
