hot keys for toggling which screen im using?
erebus720
Heres the deal:
My home theater room setup has a 32" lcd and I run a ptax100u on a 120" screen.
My original plans for switching all my devices was to use a 4x1 hdmi and a 2x1 hdmi with diodes removed so i can use it in reverse. Everything works fine EXCEPT my pc and the sceptre lcd via dvi/ hdmi cable. I cant get it looking right. So... I would like to keep my pj hooked via dvi-hdmi cable.. running @ 1280x720p then hookup my lcd via vga @ 1360x768 but be able to switch each as my main display using a hot key on my keyboard. Im not sure what software I want for this purpose. I thought of just mirroring them but my lcd wont do the same res as my pj... Thanks!
(pics coming soon!)
So I found a hot key in powerstrip that toggles main display. Its a little clumsy and doesnt work if the main display is off. Anyone know any more progs that can do this?
in nvidia control panel you can set up a hotkey to toggle between screen, each with its own resolution. You might need to power on the other display first tho.
