Hot: Gamestop DVDs Buy2Get4
Comedian
You heard me right. Gamestop is phasing out used dvds. As of Sunday the 24th, gamestop will no longer take in dvds, and will end the Buy 2 get 2 free. On monday the 25th, gamestop will start a buy two get four free in hopes of getting rid of all the stock. Remember this is on used dvds, so the edge card will save you 10% on the 2 you have to pay for.
I think the deal has always counted towards blu-rays and hd-dvds. At least thats what another store told me, I have never tried because there is usually slim pickin's in these categories.
I would assume they are phasing out used dvds to make room for blu-ray, and thus the buy2 get2 wouldn't apply. Just my guess though.
Actually they're phasing them out altogether. They have added a chain called "Movie Stop" in some areas. I've read multiple times about them getting rid of their movie selection.
I've also read about the Buy 2 Get 2 working with Blu-ray. I was just in there yesterday looking and although I didn't find any BD's I wanted, they did have them under the B2G2 banner.
its monday... anyone confirm this deal is going on?
im going to check it out later just might save me a trip if its not though
The store closest to me (Crestwood Mall, Crestwood, MO) still had the B2G2 signs up. And it really didn't mater because they only had 5 total Blu-ray movies. Two copies of Talladegga Nights, Hitch and a couple other worthless movies.
Hopefully the next one I hit up has more of a selection.
It's not all stores, confirmed in a thread @ SD.
So, you might want to put YMMV OP
The store in RI I checked out was only doing B2G2 and the guy there said that none of the other local stores were doing B2G4 so its a by store thing.
Looks like all the SD'ers are straight up clearing out the stores!
One guy cleared out 13 stores in one day.
