Hot - Basic Cheap Video -NR- X700 Pcie-16
SAPPHIRE 100122L Radeon X700 256MB 64-bit DDR PCI Express x16 Video Card - Retail
That's about what it's worth.
Nobody said it was worth anything more... This is a great pairing for specific purposes. I use one of those on my folding machine because it does not require a lot of power and is cheap and has DVI which means I won't go blind on my 19inch monitor looking at a fussy analog signal.
In total I built a Quad Core box for $470 with 2gig DDR8500, and it will be a monster folding machine. I've already had it stable at 3.1 and will push it further as the TIM cures. So while not attractive to an enthusiast it still has purposes. Try finding even a used pcie vid card at that price can be difficult.
"Hot" implies it's worth more.
For $2 more than the x700, you can get a X1550 with passive cooling, and it's even cheaper after you send in the rebate ($16.99 after $10MIR shipped): http://www.newegg.com/Product/Product.aspx?Item=N82E16814127292
The 128-bit x1550 kills the 128-bit x700, so the 64-bit versions of each should have similar relative performance.
True but the X1550 utilizes more power.
Depending on the situation you want the lowest power, lowest performing card for cheap.
I agree probably not Hot, but value for certain situations indeed.
For the price, I would go with the original post. More monitor types support and twice the video ram out the gate and less power consumption. The other one may perform better (not sure since I haven't done tests), but I would guess pretty little over all. You gain more benefit from the lesser priced card. If you want a faster game play, then you are wasting money on both of these cards no matter how you look at it. The second one says Vista compatible but reviews suggest it wasn't a simple install.
No, it actually uses much less power. The RV516 on the x1550 uses 30% less power than the x1300, and the x1300 uses about 20W less than the x700.
Gilthanis: both cards support VGA, DVI and TV out. Newegg doesn't list the accessories included, but MSI's site does. It comes with a DVI-VGA adapter in the box. The Sapphire card supports dual monitors. Vista drivers have of course improved in the over a year it has been out for consumers and you can't blame the individual manufacturers so much later for bad ATI drivers since any would have the same problems.
I'm all for arguing cards on the merits, but c'mon. The MSI card is faster, silent and cheaper. The Sapphire card runs hotter, uses a dinky heatsink with a fan (I should find my old thread when I had the 128-bit version of that card), uses more power and is slower. The only redeeming feature of that x700 card is if you want to run dual monitors.
I bought one of the x1550's for a 2nd Quad folding box that I purchased today so I will be able to speak first hand about the differences very shortly.
Regardless I almost wish we had a sticky somewhere for low priced video cards/performance would be nice to see, almost the anti Enthusiast view.
I grabbed an x700 off craigslist for $10 because I needed a card for my server... :O
I unplugged the fan because it was loud and annoying though...
