hosed vista >.<
Elios
well i hosed vista trying to get Alcohol 120 to work >.> now it BSODs on boot even in safe mode there a way to do last known good like with XP?
I've had several hard crashes, and on re-boot it gave the option of lkg, but it didn't work.
It's still beta, I just wound up re-installing...
I had the same problem with Daemon Tools, I just wanted into my XP install, and deleted the Daemon Tools driver DLL and it booted fine after that.
yea.... any one know the names of the files Alcohol uses?
The bolded ones are critical files for Alcohol, the others are mostly language files.
alcoholx.dll
AX_AR.dll
AX_BUL.dll
AX_CAT.dll
AX_Chs.dll
AX_Cht.dll
AX_CZ.dll
AX_DA.dll
AX_ES.dll
AX_FI.dll
AX_FR.dll
AX_GE.dll
AX_GR.dll
AX_HR.dll
AX_HU.dll
AX_IT.dll
AX_JPN.dll
AX_KR.dll
AX_MK.dll
AX_NL.dll
AX_PL.dll
AX_PT.dll
AX_PT_BR.dll
AX_RU.dll
AX_SK.dll
AX_SLV.dll
AX_SR.dll
AX_SV.dll
AX_UA.dll
AXShlEx.dll
AxSWind.dll
ccdmount.dll
DevSupp.dll
DPM.dll
nrgmount.dll
pdimount.dll
pfctoc.dll
i fixed it last night theres 2 files in the window/system32/drivers/ folder you need to nuke to fix it
thanks for the rest of the file list though ^^
