I've got 4 hitachi 5k3000 2TB drives in an array on a C204 board, 50GB RAID10 volume for the OS and a ~6TB RAID5 storage volume.
Transfering a multi GB file over the network to the OS volume gives the expected results, 100-110MB/s for the entirety of the transfer limited by Gbit connection, resource monitor shows spiking active time fluxuating quite randomly from 0 to sometimes 90, maybe average around 30-50, hard to tell. System cache memory slowly increases ~2GB and plateaus there.
Transfering to the RAID5 volume is a different story however, transfer starts out the same from the network side however disk active time pegs at 100%, write IO is only ~20MB/s, and cache RAM increases linearly until the RAM is full. Once RAM is full the network transfer slows to 10-20MB/sec for the rest of the transfer and the whole system becomes very unresponsive during this time due to the high disk activity.
Is this normal for software RAID5 on an intel board? Frankly I haven't used software RAID in years and the areca in my other box probably has me a little spoiled with 300MB/s+ write speeds to a RAID6 (never actually benchmarked it but I have done a file copy from the drive to itself and it did over 150MB/s on the transfer so I'm sure it could do 300+ if it was just writing), and I know the drives aren't the fastest but this seems excessively slow. If it IS normal then I'll definitely switch to a RAID10 on the data partition as well, I just want to make sure there's nothing actually wrong first...
