I set up another PC in here, I cant remember exactly what its card is. But it was some kind of 54-G belkin PCI card. The AP is belkins cheapest AP/Router, 7240-5 or something.
My PC has a $9.99 Ralink RT2500 card (which is nothing short of a miracle for that price). Im able to pull about 12-14Mbs off the belink AP with my rig. My brothers rig, similar specs but a belink PCI wifi card. Signal strength on his rig is about -40Dbm, mines closer to -20/-30 (varies). About 2 meters away from the AP, nothing else near us that can be interfering.
I first noticed the problem, when windows XP's network-neighborhood (or whatever its called now) would freeze up explorer.exe every time It tried to look at his PC. He tried downloading a 30MB .zip off the internet, barely pulling 5KBps. I was sucking nearly 90KBps from the same website.
I tried to send him a 400MB file through one of his shared folders, his download speed dropped to 2KBps and the file transfer said it had something like one day left . His ping was very good (0-2ms), just horribly slow. Fresh install of XP. Out of desperation I even factory-reset the AP/router, unplugged the router, ap, and switch and left them off for a minute and re-plugged everything back in.
For now his PC is wired into the switch with Cat5. Id like to know where to start in finding exactly what the heck is going on, since Im stumped on this one. Over cat5, his PC can pull nearly 80Mbps, over Wifi it peaks out at 5-6KBps.
