Horrible problem, need help as soon as possible.
Miller
I'm experiencing a number of problems with my computer right now:
1) It will randomly reboot after starting up for a few seconds.
2) It makes an alternating beeping noise (high tone, low tone, high tone, low tone) while displaying post code 48 (I don't know what that is and it's not listed.
3) It's only detecting one of my two disk drives.
I have no idea what's going on, and it just started doing this this past hour. I'm at a LAN, currently, and I don't think it really had anything to do with moving it, but it may have knocked something out of place. Whatever it is, I can't figure out the problem.
I've had problem 2 before, and I posted here, but no one answered.
Need help as soon as possible. Please.
Motherboard: ABIT AS8
Edit: This problem doesn't occur in safe mode (Problem 1), but problems 2 and 3 persist.
Anyone? This is a very serious problem and I would appreciate it if someone could give me some insight. I'm sorry to be so pushy, but it's a $1,600 computer that I spent all summer making money to build, and now it's essentially useless.
That sounds like the heat alarm, like the processor is overheating.
What heatsink/fan do you have on your CPU? Could it have gotten jostled and is no longer making good contact to the CPU? I'd pull the HS/fan, remove the current thermal paste, reapply and reseat the HS/fan. The hi/lo beep codes for your board (you do have an AWARD BIOS, right?) means either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed <-- taken from HERE
