horizontal mobo = better cooling?
Thuleman
Is a desktop setup with a horizontally mounted motherboard, and SI-120 better for cooling?
I know most everyone has a vertically mounted mobo, but I am wondering whether heatpipe CPU coolers will do better when mounted horizontally.
Im not to sure about the SI-120 but my thermalright SP-94 says if you mount it horizontally the cooling is better so it will probably be the same for the SI-120 as they are made by the same company.
Since we all know heat rises, it would make sense that a H setup would be more efficient than a V setup, but in the end it would depend on how much hot air you can exhaust from your case IMO. As an example, I have yet to see a H case w/ exhaust vents on the top of the case :confused:
I suggest that efficient case ventilation - efficient forced volumetric air flow-through - is much more important than orientation of the plane of the motherboard.
If internal case temps are your primary concern, I would be much more concerned about efficently replacing accumulating warm air with cooler ambient room air.
I would consider board plane orientation as a form-factor, convenience or personal preference issue.
Hope this helps!
