Horizontal lines in GDM-FW900
bigbolide
I just got this from a friend of mine who is a photographer. It looks quite good at his home, but when I took this beast home, I noticed two horizontal lines on the screen. Is it normal? I did not recall there was any in his place, so wonder if this would possibly caused by transportation as I just put the monitor on my back seat (a sedan and the trunk could not fit).
I did a research, and found this could possibly be the aperture grille damper wire. But I still want to know if it is, as after I tried to restart, I saw another one on the bottom (about 1/6 of the screen). I did a print screen, found out that it was not on saved jpg file, so guess it was just on the panel. Here is the picture link (the previous are the print screen, and the other two were taken by my only DC see the lines pointed out by the mouse):
http://picasaweb.google.com/xinyangster/GDMFW900Problem?authkey=kLpYcCAkjr0
So would that be the wire? Two? Anyone could help me on this? I googled and found this an awesome place. I do not play games so much, but do need a good monitor to process my photography works. Thanks a lot.
Yes those are the damper wires and are perfectly normal, all Trinitron/Diamondtron monitors have them. After awhile you won't even notice them anymore.
The two lines are both the wire?
I have a dell desktop with a E248WFP monitor. Any compare between these two? Which do you recommend for photoshop editing? Thanks a lot.
Yes both lines are the damper wires. My 21" Sony G520P monitor also has 2 of them and i even have a 30" Sony CRT HDTV that has 3 of them.
As for photoshop editing theres no question the FW900 is superior, its color accuracy cannot be matched by any LCD. I read a story awhile back that the production crew for the movie 300 bought like 40 FW900's to edit the movie because they couldn't find anything else with good enough color. That should tell you something right there.
Dang. Nice camera. The damper wire line in your last pic looks just like the real damper wire line on my FW900. I was having a hard time telling them apart.
That definitely looks like an aperture grill wire line to me. 2, like we have, is the normal number for monitors, though small Trinitrons (15", maybe 17"?... not sure) sometimes only have one and as Toompra points out really large screens may have more.
Thanks guys. This is really helpful and I think I will leave the new dell one on Evil Bay:). And this monitor was owned by a studio photographer. He gave it to me as a gift. It seems I got a good deal:cool:
I was looking at your pics and I thought I was looking at your damper wires but I was seeing mine HAHAHAHAHA
