Horizontal Fan ?
AP514
Ok im looking for a good Horizontal fan....I know not to use Sleeve due to fact the bearing is not set up for that position..so what type bearing should I use in that position(will be my top Fan) ??
AP514
There really is only Sleeve and Ball, as I consider the hydraulic (or semi, whatever) to be a sleeve still.
Though I must admit, I thought this is what you were asking for based on the topic ;)
images
Which for those not knowing, has this inside:
images
If you mean a horizontally mounted computer fan, then there's Hydrodynamic and ball bearing, and that's about it. Sleeve fans in general don't like being mounted that way, and my experience with an Enermax Marathon Enlobal Magnetic Bearing fan left with the opinion that I'd rather have a sleeve bearing. Not that I don't think maglev type bearings don't have great potential, but that particular one was just no good.
