Horizontal Fan
Droc
Quick question
Im replacing the top fan in my P180 case and for the life of me I cant think of a fan to use. Im replacing the rest with yates but I dont think I can use them horizontally due to the fluid dynamic bearings correct?
Sleeve bearing fans are the ones with issues running horizontally. The best fans to use would be Scythe Gentle Typhoons if you have the budget for them.
