tim_m
i'm so nice
- Feb 10, 2003
i've managed to install horde 2.2.7 so that i can eventually use imp. i've followed the INSTALL file but i've confused by step 5 in configuring horde
http://www.horde.org/horde/docs/?f=INSTALL.html#configuring-horde
it says
there is no 'admin' folder in the 2.2.7 release apparantly so i have no idea how i'm supposed to configure it. i suppose i could just get imp working by manually editing the conf files and not have to use horde's login but i at least want horde runnig correctly first.
thanks for any ideas
it says
but i don't see how i can log in without a username/password. i made myself an acount in the database and it lets me login with that but there are no admin options.You can now access Horde without a password, and you will be logged in as an administrator. You should first configure a real authentication backend. Click on Configuration in the Administration menu and configure Horde. Start in the Authentication tab.
