I just heard from the insurance company that theres a check on the way to me to cover damage of my primary towers (lightning). Guess its time to build a new box. My intent is to use the box for gaming as well as work. Id like to buy into hardware that will serve me well for 3-5 years if possible.
I was considering the following configuration,and would love to hear what you all think:
ASUS P5AD2 Premium
Intel 3.6 P4 560
PC Power and Cooling Turbo Cool 510 Deluxe Express
Crucial 1 GB PC-4200U DDR2/533
300GB Maxtor Diamondmax 10 plus (16MB cache)
Sony DRU-700A
Creative Audigy2 ZS
Areas that I need some help in include:
1.)What kind of case should I put this in? Pretty is not as important to me as easy to work on. Im also not looking for a LAN friendly box, as I have a laptop for that.
2.)Can I scrap the Audigy in favor of using the onboad sound the ASUS mobo provides? Is there that much of a difference? Ill not likely use the system in 5.1/7.1 configuration anyway due to space limitations.
3.)Is the P5AD2 the crème of the current PCI-X mobos? Is there another option that would eclipse it?
4.)I think I want to get a 6800 Ultra as the video card for this rig. Which brand do you suggest, and why?
5.)On the memory front, is there a huge difference between DDR2 (667) 5400 - 1 GB (2 pcs 512) Corsair and the memory quoted above?
6.)To RAID or not to RAID. Should I get 2 of the drives and run them in RAID 0?
7.)Are any of the above listed components sub par for a high end gaming / work machine? If so, what would you replace?
8.)I usually deal with New Egg, but see that Monarch has some decent prices on items as well. Is there any vendors you guys give high marks to, or any that should be avoided at all costs?
Any other advice or words of wisdom are appreciated.
ASUS P5AD2 Premium
Intel 3.6 P4 560
Sony DRU-700A
Creative Audigy2 ZS
