You can find the FAQ at http://www.hardforum.com/showthread.php?t=844140GodsMadClown said:[size=+2]How do I connect my PC to my home theater system? [/size]
The quickest and easiest way to connect a PC to a home theater system is to use a 1/8" jack-RCA adaptor. Plug the 1/8" minijack end into the appropriate soundcard output, and plug the RCA ends to an available input on your audio equipment.
Alternately, you can use a digital connection of either the optical or coaxial variety. This typically carries only a stereo signal, unless you are playing back a previously encoded digital stream
