hooking up a pc to hdtv
zidion
i got bored and hooked up my pc to my hdtv last night via s-video cable, and it was awesome, except the res was a little low.
someone told me that 1080i is 1920x1080, but i could only get mine up to 1280 * 720.
do I need like a special cable to get the 1080i? Cuz i would really like to do it. I had a blast last night playing UT2k4 on teh big screen :)
you are on the [H] and have a dvi card you should know better than to use s-video....id bitch slap you if I could...:)
you need to check and see what inputs your HDTV has....if it has dvi..then you have your answer about 1080i and all that..
ok i checked it out and it only has s-video and compenent video
what can i do?
yea :(
it was only like $450 for 27", but its HDTV and progressive scan
zidion said:
yea :(
oof thats why. From what i know only the bigger hdtv's have dvi.
If you have an ATI card, grab one of these: DVI-I to HDTV Component .
I have one for my HTPC and it works great.
I also saw in the latest NVidia driver release that they added support for a HDTV component adapter. I have no idea if this same adapter will work with NVidia or if they require a different one.
Garage81 said:
well, 450 bucks is a good price for that :D
yea, it was orginally $600, but it was 'open box' so i got it for 450 at best buy :) :) :)
only problem is its a company ive never heard of, but for the price i could realyl care less
thats pretty tight, i might email nvidia about it
