EnigmaPrime
- Aug 22, 2008
Hooking Plasma EDTV to PC
OK, I have a Philips 42" plasma EDTV
http://www.hdtvsolutions.com/pdf/42pf9936d_37_pss_aen.pdf
I have a Nvidia e-Geforce 8800gt Video card installed in my pc.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318
I have a HDMI TO DVI Cable
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189056
Picture/Display
Aspect ratio: 16:9
Brightness: 1000 cd/m²
Contrast ratio (typical): 3000:1
Diagonal screen size: 42 inch / 107 cm
Visible diagonal screen size: 107 cm
Display screen type: WVGA Plasma panel
Picture enhancement: 3/2 - 2/2 motion pull
down, Active Control + Light sensor, Comb
Filter Digital, Digital Crystal Clear, Progressive
Scan, Widescreen Plus
Screen enhancement: Anti ageing circuit, Anti-
Reflection coated screen
Viewing angle (H / V): 160 / 160 degree
Panel resolution: 852 x 480p
Response time (typical): 16 ms
Supported Display Resolution
Computer formats
Resolution Refresh rate
640 x 480 60, 67, 72, 75Hz
800 x 600 56, 60, 72, 75Hz
1024 x 768 60, 70, 75Hz
Video Formats
640 x 480p 2Fh
Supported Display Resolutions
Standard Resolution Refresh Rate
VGA 640 x 480 60, 72, 75, 85Hz
VGA 720 x 400 70, 85Hz
VGA 640 x 350 70, 85Hz
MAC 640 x 480 66.67
MAC 832 x 624 74.55
SVGA 800 x 600 56, 60, 72, 75,85Hz
XGA 1024 x 768 60, 70, 75, 85Hz
WXGA 1280 x 768 60, 75Hz
I'm trying to get the best output from the computer using either the HDMI to DVI cable.
but what ever setting I use part of the picture from HD shows I have on my PC are missing around the edges, not allot but enough to annoy me.
I previously used DVI to DVI but since I had an available HDMI port on the TV I figured it would be a better picture.
Can anyone point me in the correct direction as to the appropriate cables & what settings to use.
TV has S-Video, DVI, Composite(used for comcast box) & HDMI
Thanks in advance
Picture/Display
Aspect ratio: 16:9
Computer formats
Video Formats
640 x 480p 2Fh
MAC 640 x 480 66.67
MAC 832 x 624 74.55
Thanks in advance
