Hooking 7.1 up to TV
MrHood22
I just got a new TV and the last thing I need to do to have it completely set up is hook up my speakers. On my old TV I had it rigged up through splitters. I know that's not the best way to do it but my goal was to have it come out of all 7 speakers and that's what it did. Before I had 3 cables from the speakers (green, black, orange) but I only had 2 RCA audio ports (red, white) so I had to get 2 splitters to plug into the '3.5mm to RCA' adapter. Basically I had the RCA adapter plugged into the TV, a 3.5mm splitter (#1) plugged into RCA, The green Cable and another splitter (#2) plugged into splitter #1. I then had the green and orange cables plugged into splitter #2.
I tried that set up and it did not work on my new TV. I think my next purchase will be a receiver but in the mean time I would like to at least use my 7.1 speakers.
TV: http://www.amazon.com/gp/product/B004MFDL14/ref=oh_o01_s00_i00_details
Wait, if I get you right you're hooking up speakers DIRECTLY into the tv without a receiver of any kind? Why? If I were you I'd hold off on the tv and spend half as much for a cheap receiver first.
If it was between hooking the speakers DIRECTLY into the TV or not hooking them up at all, you still wouldn't hook them up?
To clarify, I ALREADY have the TV. I've also noted in my first post that I do intend to get a receiver in the near future but I would like to temporarily hook it directly in. I realize this is not the best method.
