hook a ps2 up to your pc, is it possible?
XeRo_Dark
i was just wondering if its possible to hook your ps2 up to your computer, so u can use ur sound card, and speakers with it, along with using your monitor with it?
is there some sort of adapter for it, if so linky me please :D
hmm most tv tuner cards dont have the red yellow and blue jacks do u recommend any cheaps ones that do
I got a special cable for my ps2 that had svideo out. My tuner card takes both s video and audio video in and svideo had a very noticably nicer look to it.
Do yourself a favor and just buy a VGA box, which will convert from most major inputs (Composite, Component, S-Video) and go directly into the monitor. These are widely available on eBay if you search under PS2 Converter or PS2 VGA Box or something to that effect. The major problem with TV cards for this purpose is that there can be considerable lag as the signal is decoded. I have a VGA Box I got off eBay for about $40 and it works well.
Also try Lik-Sang, they have a bunch that are platform independent.
My monitor has component connectors and Svideo in. So my PS2 is hooked up that way...
