I have this idea bouncing around in my head about making a homemade cooling unit for a water-cooled system. My system will be sitting on a monster oak desk, in an unfinished basement. I want to make a insulated 8 to 10" wide cylinder about 3 or 4' long, and mount it to my wall. I would fit as much copper pipe as would reasonably fit, secured to the inside walls in a spiral pattern. Copper would be selected it's good thurmal-conductiveness(?). I would want as much heat as possible, to transfer through the pipe and meet the cold. I would fill the 4' long 10" wide cylinder with ice water, for the PC's warmed liquid to travel through. I have a water pipe located real close to my computer, that I could install a perminant spiget, to be located directly above my cooling unit. I would just pop open the lid, turn on the water for ease of filling. I also have a drain in the floor 6' away from the wall. A small section of retractable hose, could get me there real easy. Not as much trouble with filling and draining such a unit, as one might initially think for my situaction. I think I could pick up a small ice maker too, and hook it up real easy in my basement.
The question is would this be a better cooler than your standard store baught water cooling unit? If so, I don't think I would mind the maint. I never move my PC around, and would enjoy showing it to my friends, and taking tempature readings and all....
I have never built a rig before from scratch, and have never even seen a water cooled rig in person. I just know I will be building a water cooled rig soon, and thought I might have some fun with the cooler. I would do a good job, and install temp sensors on both the in and out. I am thinking I would need to match the copper pipe size, to as close to the hose size that is run in the PC, so I wouldn't have a bottleneck in the flow....
Probably will use the TJ09 case, and put them pre-cutt water holes in the back to good use...
Good or bad idea? Any thoughts feel free...
