home theater speakers
id like to spend under 300 to get some good sound for my desktop and my dvd player. and i dont wanna watch dvds on the desktop
id like something with a remote as well so i dont have to get off my ass to change the volume
ok maybe i wasnt too clear but this is what i want...
i want some kind of audio system with speakers where i can hook it up to my computer and my dvd player as well. and this system has to be fairly cheap like under 270 so i can buy a new sound card as well. with a home theater in a box solution be good?
i know the expensive recievers can support up to like 9 or so devices and switch between them so they can all use the same speakers. not at the same time though of course. so im wondering do these cheap home theater in a box these cheap home theatre in a box solution contain a reciever that can be hooked up to at least 2 devices?
For $300, get a Klipsch Promedia 5.1 set.
If you want a decent HT-style surround computer rig You'll likely need to spend more.
, go for a b-stock reciever.
http://www.clubonkyo.com/reward_earn.cfm
First join ClubOnkyo for the $10 discount
Then go to shoponkyo.com.
You want the refurb TX-SR501.
$185 - $10 (bonus points) + shipping = <$200
https://www.shoponkyo.com/catalog_detail.cfm?id=TX-SR501&type=3&class=Receiver&p=i&ext_war=1
then get a set of b-stock Rocket Tykes from Av123.com for $299.
My inclination would be to get by with a stereo pair for now, then you can upgrade later.
Also, try to check Craigslist for a decent used receiver. Look for a model that has multichannel analog inputs.
