CountZukula
- Sep 11, 2009
First off: there's a lot of threads and info to be found on the internet regarding NAS / general servers but as it almost never really matches what I need I'd thought to create a seperate thread for it. All parts needed will be purchased new on as low a budget as possible.
The plan: build a server containing a raid-5 array, expandable towards the future, as cheap and energy efficient as possible. It will mostly be used as a file server running OpenSolaris (ZFS) but needs to be able to run a webserver / mailserver / database / ... on a small scale (home development or small personal sites, nothing enormous). It's not the plan to make into an entertainment system of some sort, so graphics / audio processing power can be disregarded.
So far I've been looking at a 775 proc / mobo with 6+ SATA connectors and 1gbitE onboard. For the drives themselves I was thinking of the WD Green series. As far as the case goes, a cheap coolermaster caught my eye, enough bays to host 6 disks and space for 2 fans (front, back). Are there parts (mobo / proc / case) widely regarded as the optimal solution for this setup? Are the parts I was thinking of somewhat in the correct direction? Any suggestions regarding the setup (software / disk management / ...)?
thanks
thanks
