Home "server" ECC memory choice?
Florin22xxl
Hi guys,
I am building a home computer wich will be used to stream 24/7 and i am looking to get some ECC memory.
I need this computer to run 24/7 so system stability and 0 downtime is what i am going after.
I do not care about speed.
Other computer parts are Gigabyte x370 k7 / Ryzen 5 1600x.
What do you think of my ram choice?:
https://www.amazon.com/Crucial-DDR4-2666-2Gx72-Server-Memory/dp/B01N9JOE2K
It is the cheapest ECC ram module out there,but as i said i don't care about speed,i only want stability.
Would a better brand offer me better stability/longevity?
Thanks!
pitingres
and you'll have to double check the motherboard, many AM4 mobos "support" ECC in that it will run, but they don't actually do error correction. Asrock Taichi and Asus X470 Prime Pro are two boards that reputedly do error correction, you'll want to research to confirm that.
ekiro
i recommend buying ram from memory.net. Great prices. Best selection.
