VladDracule
- Feb 5, 2007
Hello all,
I am running a comcast wireless gateway, and an asus AC66u router. The router doesnt have enough ethernet ports for all of my devices (currently has Denon Receiver, seagate Central network drive, Xbox 360, and Xbox One wired in). I have my PS4 wired into one of the 4 wireless gateways ethernet ports.
My issue is that it seems as though the gateway and router are trying to set up multiple networks. My PS Vita is unable to locate my PS4 on the network because it is connected wifi to the Linksys router. I had the same issue with the network drive, if i used the ethernet on the modem i was unable to connect to it using ANY of my devices on the router.
Is there a work-around for this?
