Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
you can get cable for 25 bucks for 1000 feet. make it yourself out of that roll.
NIC's, if you shop around, arent more than 3-5 dollars. (i got a 6 dollar linksys 10/100 the other day)
but for quality
buy pre-made cat6
get intel pro NICs
#1 - I have a cat6 cable gonig from my router to my comp.
#2 - One of my comp's in the network is going to be very crappy, and will not run with XP. Does it make it hard to have a network if one comp has win95/2000?
#3 Where are some tutorials on setting up networks?
Sorry Fury, thaqt site just isn't much help to me, keep in mind, i have NO experiance with networks or anything of the sort, and I just can't quite grasp the concept from that site.
If anyone knows site better fit for a newcomer, that would be appreiciated. If not, I guess this is a lost cuase
It may be beneficial for you to post what you're hoping to achieve with this network... Is it to connect your computers to the internet? Do you want to share files between the computers? Play games?
Are you going to be able to do the physical part of the setup? Actually installing the NIC's and plugging in the cables to the router appropriately?
if all you want to do is have everyone get online its simple, plug in your modem, then your router, then your comptuers then turn them on. if you want to share files, you just have to enable the file sharing and look for the computer or the file itself this may need administrator password, and or privledges.
you can get some damn good NICs (network interface card) for $10 or if you have a micro center nere you, after rebate $1, (hawking technologies i think, every pc ive put them in sofar, they work damn good, are instaled instantly w/o their driver CD... just all around a good product, its what i use in my server, my family pc, my friends pc, (my lap top and gaming rig have onbaord )
