hi
When recently trying to transfer files i found myself setting up a home network with a laptop that has never been connected to my desktop before.
I am connected to the iunternet via a sattelite which uses on of those blue lan cables. the sattelite connects into a switch which is then plugged into my computer. Thr laptop is then plugged into the switch via a lan cable. The Network Connection is fine so its no trouble with the hardware or setup. I then ran the "Network Setup Wizard" on the Laptop and on the Desktop pc. I turned file and printer sharing on.
After restarting and going into "My Network Places" on The laptop is has an icon for itself and the main desktop. but when i click on the desktop it says
"\\(computer name) is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions" and then down the bottom "The network path was not found."
And when going into "view Workgroup computers" on the main desktop there is an icon for itself but not for the laptop .
btw i can play games across the two computers.
please help.
please help.
