Fort_Major
- Apr 22, 2006
So I am currently fed up with current available router/switch solutions. Most seem to be only 4 port and you literally have next to no amount of control what so ever so I am pondering trying to see if i can build my own home made router.
I am looking at 2 quad port ethernets as I need to be able to connect up to 6 users via wired.
Several caveats.
VOIP: I use voip through vonage currently. I have tried before and the vonage router does not seem to like being behind anonther router. What are my options for this?
Management: Okay, let's face it - no flame war intended, however Linux users ideas of management are usually completely different from windows's users ideas. I am looking for ease of use for management.
Basically, my problem is that I need to be able to ensure that certain network users are limited on. That being said. I want to be able to easily in an instant be able to see how many users are connected to the internet. how much they are downloading, how much they are uploading
Controlwise I would like to (if possible require users to authenticate to get on the network- not sure if this can be done with standard windows networking or not)
then based upon user authenticated as rules apply. Since my main goal is to "limit" the amount of P2P Ideally I am guessing that I would like to be able to rate via port ranges or via protocol
So in summation Any suggestions regarding motherboard/case are welcomed as are solutions to my voip dilemma and also possibly software for firewall/network/routing management would be appreciated.
Several caveats.
