I was surfing and saw a review on this fan duct this. Basically we all know this, supposed to help create less of a dead spot from the hub of your fan.
I decided to try it and see for myself. I took a old 80mm fan and cut the fan out. I then took my trusty dremel and grinded the inside so it was nice and smooth on the inside. I kept the overall shape inside, so the fan will force the air towards the middle of the heatsink where the dead spot normally would be.
My heatsink is the Silent boost. I got a fan from a [H] member (thanks zeebs). Its a Sunon 45CFM (3500RPM), at 36db. I noticed that it was alot louder then anything in my case. After this was done, the vibration sound dropped a TON. I could no longer hear it over my Fan card. That alone impressed me.
I took the hollowed fan, attached it to the heatsink, then attach my Sunon to it using small zip ties. I used the Silent boost stock screws and just ran a small screwdriver right through the fan's screw holes.
End result is pretty good. I got a 2-3C drop on idle and 1-2C drop in load temps. Nothing to stop the press over, but hey it didnt cost me anything but time and a old 80mm fan.
Here is the finished result....seriously it performed alot better then i thought it would.
So, a old fan 0$, 4 zip ties 0$, 15mins 0$, for a 2-3C drop in temp, priceless.
