Home file server build
desmopilot
--- will be used as a home server for hosting my files and backups
--- not a specific budget but would like to keep the cost low. Will be buying from NCIX.com as its local and I can pick the parts up
3) Where do you live?
--- Vancouver, Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
--- CPU, mobo, RAM, HDD(s), video card if need be, case and PSU
--- nothing
6) Will you be overclocking?
--- nope
-- not needed
--- tomorrow if possible
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
--- Just a PCI-E port would be nice, at least 2 SATA ports
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
--- Have a spare copy of Win 7 x64 from work; but maybe I could try out a linux distro?
Just looking to build a simple home file server and backup rig. Thinking an Atom would be perfect for such a task; at the moment I'm looking to base the build around an "Intel D510MO" Mini-ITX board. Couple quick notes:
- 2TB would be enough space
- Case, don't want it too big but doesn't necessarily have to be a SFF case.
- system will, of course, be on 24/7
Thanks.
Acer Aspire Easystore or ASUS Ts Mini Server
the problem is that you cant get a dual core atom out of a prebuilt.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108196
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121399
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
thats 165 but didn't include the hard drive(s) that little case can hold 2 so its up to you how you want to do it.. I can say though I am a fan of the Samsung Eco Drives. I have 3 of them in my WHS with that same board & they have all been flawless.
Really liking your suggestions Bastage. One question, does the D510MO come with onboard video? Can't seem to find a definite answer.
