What have people been using software wise as their own home built iSCSI targets for ESXi? A lot of people in the Virtualization forum i notice just get a Synology or something like that but A) more fun building your own B) cheaper.
If you are looking for a free High-End SAN solution, look at ZFS (ex OpenIndiana)
But I would prefer NFS over iSCSI (You can access Snapshots and Move/ Copy/ Backup
from Windows via NFS or SMB) while its similar in speed.
Gea
Is it safe to use snapshots/copy/etc even though Windows VSS is unaware of it? I thought that wasn't recommended.
I setup an OpenIndiana/Napp-it box and haven't looked back. Even though it has iSCSI as an option, I just use NFS and SMB as Gea suggested. On top of that..my raidz pools are performaning exceptionally well especially with the large amount of ram and SSD cash I have.
Believe me when I tell you, i've used a lot of storage target software such as Starwind iSCSI, Windows iSCSI targets, HPP4000 VSA, the EMC Uber VSA..etc, and nothing has come close in performance, from a build your own standpoint. On top of that, it's simple to setup, just make sure that you have supported hardware.
Pure ZFS snapshots do not care about ESXi and guest-OS
-> good if you just need the file state, you can hold thousands of such snaps
If you need hot snaps for ESXi (with memory state)
do a ESXi snap, do a ZFS snap and delete ESXi snap (ESXi snaps are very limited)
now you can go back to this ZFS snap and restore a running ESXi VM
if you need hot snaps within a special VM where a Hot-Snap if ESXi is not enough,
you have to pause/ shutdown vor VM or you need VM internal snaps.
A ZFS only snapshot is like the state after a power failure.
Most systems can handle such a failure in most cases especially
because the filesystem itself is always consistent.
Gea
This means you've failed to configure your SAN properly
OK, MS iSCSI target is definitely on a slow side, HP & EMC were virtualized so everything is clear and you should have wire speed with StarWind or any other GOOD iSCSI SAN. ~950MB/sec and 5 ms latency is what you should expect with 10 GbE. No NFS would stand even close to this. So... Show us your benchmark results or it never happened
Olga
Olga
Here's a benchmark on 1 Gbit and 10 Gbit Ethernet (FCoE[10Gbit only], iSCSI, NFS) and 4/8 Gbit FC. The conclusion? The differences weren't that dramatic.
http://media.netapp.com/documents/tr-3916.pdf
It doesn't take a genius to setup Starwind iSCSI, and let's look at reality, barely anyone is using 10Gbe for home use. That's what I was talking about. I didn't take any benchmarks and i'm not about to set up a new environment, but I can tell you this, using NFS w/OpenIndiana and my ZFS pools w/SSD cache for my VMware lab, there is a visible difference. Now, this could be the fact that I was using SATA only with Starwind and there wasn't a similiar setup for Cache like I have with my ZFS pools.
And I agree..thank you tonyb for the article.
OMG
Did anybody actually bother to read this one? Or at least take a closer look at the pictures they had published?
They used 4KB and 8KB block sizes with random I/O pattern. Good for NetApp's implementation of NFS cached entirely at hardware level (no actual data is written but transaction log is held for a while before writing WAFL consistency point), bad for 10 GbE iSCSI (hard disk seeks are comparable with the network latency they're trying to measure) and absolutely killer for FC (obvious, payload size is pretty close to the frame size).
Good luck..........................
One thing that really bothers me with Netapp's whitepapers and tests and things they don't tell you is that Netapp's implementation of iSCSI really isn't native, and that it's implemented ontop of their propietary file system:
http://thesantechnologist.com/?p=52
I would like to see Netapp's NFS comparied to other vendors ISCSI numbers and not Netapp's 'version' of it. I'm not debating the ease of use that NFS presents, just the skewed performance numbers.
@NetJunkie
I realize you cant do multipathing but could you not just use LACP/Trunking & VLANs to obtain the same results w/ NFS?
So say Fibre Channel or 10Gb isn't an option?
The only reason some people still push for it is that you can multipath iSCSI...can't do that with NFS, yet.
