w00ty said:well i want to make a hole for a new fan im going to be installing on one of the sides of my X-Qpack and i was wondering how cutting the plastic window with a hole saw would work (since i dont have a dremel). its standard, cheapo plastic.
MajorDomo said:Hole saws will work on thin plastics, but run the drill in reverse, it will still cut a clean hole and not melt the plastic.
Well, share man! Share!Susquehannock said:...I have found a better method for plastic fan holes, but it involves an air compressor.
Sure ...... pneumatic die grinder, double-cut carbide rotary file (w/drill tip).sn3ak3rp1mp said:Well, share man! Share!
Susquehannock said:And you don't have to limit yourself to circles![]()
Yep, here* is one for $8. Notice the trigger paddle design. No safety catch to get in your way.jackofalltrades said:Harbour freight air die grinder cost about 9 bucks if I remember right.
