Holding out for next gen hardware?
Hey,
anyone else not satisfied with the performce increase between AMD xp to amd 64bit yet?
Iv been researching alot about the new cpu's/video cards and to me it dosnt seam worth it in investing 1000$ or so for only about 40% increase in general speed?
I have a friend with a Vinc at 2.400 and 7800gtx and its nothing from me going from my 900mhz amd w/ gf3 to 2700thunderbird 1gig ram and 9700
anyone know when we will see a 100% increase over last gens hardware speed?
Never. Hardware advances so fast that once you get something that could be considered "100% better" there'll be something even better. You can never stay on top of it, which is why I choose to stay a generation or so behind.
for me at least it dosnt seem worth the $ to rebuild becouse the system i have now isnt all that "slow"
anyone have any info on the stuff we should be seeing next year?
40% ! you think that's small? that's huge. amd xp is old and slower than amd64.
we have stop at 3.8ghz for intel, intel is having a difficult time making anything faster than that. that's why we are now getting to dual processors (2 better than one).
i know all about the dual core cpu's but im not realy doing 2 things at once
but the snappyness in desktop use will be nice
iv looked into 64bit benchmarks (where there running real 64bit apps) and they tend to be slower becouse of the raw 64bit drivers
the new stuff dosnt seam as earth shattering as i would have hoped
if youre happy with your current setup then thats all that matters :cool:
save your money for when you feel you really do need a upgrade
