Flogger23m
- Jun 19, 2009
The quest menu literally tells you if it's a main quest or not. New main quests will pop as well, so you don't have to go around looking for one to continue forward. It's pretty automated.
Since it's easy to tell apart a main quest from a side quest, be mindful to not do too many main quests in a row if you want to hit that 40 hour mark. Putting 40+ hours in this game is very doable IMHO.
Thanks. I get tired of games where you take on a quest only for it to be a fetch quest or some repeating type of thing.
The world itself looks fairly good. Small map apparently, but filled with lots of things to see and do. That makes me want to give it a try because most open worlds are empty and bland. This seems to do the concept right from the sound of things.
