Hmm would this work?
Coreyo
Hey what you put like a Ice Freezer pack thingy in a Towel and put it front of your intake fan just for that really cool air? Coul;d it possibly lower temps?
Probably only as part of a cohesive whole.....meaning that nice cold air will dissipate pretty fast if mixed with warm case air. Check airflow out, hot zones, and the quality if the hs/f you have on there now. I'd be curious to know if temp changed at all if done by itself. It would have to be substantial for me to put a high maintenance object and a towel in front of my case.
Put on infront of both intake fans and hope the exhuast fans do their job?
wouldnt there be some sort of condensation from that when the air is colder then ambient?
No don't do that just get the PC Aircon if you really need one. Link
Without PAC 400 PAC 400 FAN PAC 400 SNOW
Case---------23.5-------22.5------------------21.5
CPU----------29----------28--------------------27.5
Video Card-28----------27--------------------26
Hard Drive--26----------25--------------------24
Temp in C.
That looks cool and all besides that its 100 dollars for a couple degrees of cooling. But its a very intresting thingy.
Maybe you could put liek 3 in there for ultimate cooling!?!?!?
But you would have to have alot of space,
