hmm.. v1000 or p180?
ok this is my problem.
i love the v1000, but my only problem with it is that because of the mesh front and back, i suspect it will be a bit noisier.
the p180 on the other hand is designed to be very quiet. however, correct me if im wrong, but isn't some of that case plastic? such as the edges around the door?
which one do i go for? is the mesh on the v1000 gonna make it much louder or no?
I have a V1100 and it is quite. It is the same V1000 but with a front door and a lot of sound deadening material. I love it and will still keep it for the next time I upgrade the system. As for the V1000, all the reviews that I have seen say the case is quiet. The link will send you to 8 reviews about the V1000. I have never saw a review that did not praise the case.
http://www.hardforum.com/showthread.php?t=929438
