Darn overclocking addiction it started out just wanting a small 2.4ghz OC well that never happened so far these are the overclocks I've gone through: 2.13 > 2.66 > 2.72 > 2.88 > 3.15ghz.
My latest overclock is 3.15ghz:
e6400@3.15 (450x7) 1.35v
2gb PQI DDR667@900mhz 5-5-5-12 1:1 ratio 2.1v
(g)MCH +0.2V
I have a feeling it should be stable as 1.35v is plenty for it. I don't think I will be going any further even though that's what I said the other times to myself. But this time I will definitely need an aftermarket heatsink to go any further as I've just about reached the limits of the stock intel cooler. Anyways idle is 54*C/53*C which is seeming quite cool.
Couple of questions
1. I just opened up the computer and touched the naked ram sticks and they were feeling quite hot is this normal? and can it damage the ram?
2. I take it, it wouldn't be a bad idea to chuck another 80mm fan in the side of my case as an intake to get some more airflow over the ram and cool stuff down? I currently have just an 80mm intake at the front and an 80mm out-take at the back.
(g)MCH +0.2V
Couple of questions
