Hmm, removing push-pin from bracket...
Dev1ant
Well, I purchased a Thermalright Bolt-thru kit to replace the push pin system on a Xigmatek S1283.
How would you go about removing the push pins from the Xigmatek S1283 retention brackets?
I can't seem to figure it out with breaking the actually push pins itself with a hammer and it's quite frustrating.
EDIT: Nvm....decided to just break them off.
