hmm Missing the fan bracket?
magik20
This PC just came in.... and its missing a pretty important component.... A fan!
The kid couldnt figure out why his PC hes piecing together wouldnt work.. lol.... well its a good lesson for him
anyways....below i posted the board he has installed... As you noticed it doesnt seem to come STOCK with a Fan Bracket... just holes...
If i order this fan.... will i still need to track down a bracket?http://www.newegg.com/Product/Product.aspx?Item=N82E16835150056
It doesn't need a bracket. The fan attaches to through the 4 holes. Look at the heatsink mounting instructions.
Not suppose to be a bracket... holes are all you need. Either pushpin or screw-in with backplate fan is what ya need.
It looks like every single socket 775 board I've ever seen. The HSF comes with push-pins as other have stated. It even has instructions....
hmm my fault, I personally use AMD boards alot and the bracket comes with the board.
