chinkecheese
- Oct 23, 2007
Copied this format from another thread
PARTS:
A - Pump - Possibly the Danger Den DD-CPX1
B - Case - Corsair 600T
C - Radiator - MCR320 either a Phobya Extreme Quad, or a Phobya 200mm
D - Power Supply - Probably 1000w, or a corsair 850 if I can't find a good deal.
E - Reservoir - ??
I still have alot of research to do, but I had a few questions..
Any input on the MCR320? Having a built in reservoir is pretty handy, and keeps space usage efficient. Would I need to use a fillport if I had this?
Another question, what would you recommend, the Phobya Extreme Quad or 200mm? The fans would either be 4x120 S-flex low rpm, or a 180mm FM silverstone
Side note: This will be cooling a 2700k Oced and 2x460 GTXs SLI
Thanks!
I ditched my res/radiator idea, and am now going to use a reservoir/fillport to replace the fan controller. Thing sucks apparently anyway.
i guess this really only applies to 600T users but what do you guys think?
Here is what could be? I'm totally bad at this.
[IMG=http://img805.imageshack.us/img805/8831/corsairgraphite600tside.jpg][/IMG]
Uploaded with ImageShack.us
Red - Fillport Purple - Tube w/ fittings Green - Res
PARTS:
E - Reservoir - ??
Thanks!
