Hitman Tribute PC- Concept 2/4/08
Matrix-D
I just got a hold of an old Lian-Li PC-86 case along with some used MNPCTECH hardware, so I'm about ready to start a mod I've been thinking about for a while: a computer based on the Edios Interactive Hitman francise, my favorite game series.
Here's what the stock case looks like:
My objective is a clean, well designed case. I want it to look spectacular but I don't want to anything beyond my ability and end up with a mediocre result. Ideally this case will be adorning my desk for a very long time.
I'm a sketchup noob, but I managed to produce a fairly accurate representation of what I want the case to look like. To the best of my knowledge, everything is to scale.
Here's a brief synopsis of my plan:
Front- If my budget allows, everything will be powder coated either black or red (except the mobo tray, more on that later). The color sceme for each exterior piece can be seen in the sketches. The drive bays will hold one CD/DVD cover, one Lian Li fan controller (I'll replace the LED's with red ones), vandal resistant power and reset switches along with a power and HDD light, and four toggle switches which will control the LED light strips inside the case. The drive bays will be trimmed with aluminum and the area below them will be red round hole modders mesh (hard to see in the picture that it's mesh). I'm going to put a 120mm aluminum blowhole on the front, but instead of putting a fan behind it, I plan to use a circle of translucent red acrylic with the hitman logo cut out of aluminum. The fans will be placed elsewhere...
Right Panel- To get the picture on the right panel, I plan to cut a window-like hole with transparent red acrylic behind it. Behind this acrylic sheet, I'm going to put a piece of mirrored red acrylic. Sandwhiched in between will be the image printed on a large transparency.
Left Panel- The larger window on the left panel will be similar to the right panel window except that both acrylic pieces will be transparent so that the case can be seen into. The smaller window is the "mission window." It will be transparent red acrylic and the names of eight key missions from the four games will be printed on it. However, it will be backed by a thin sheet of translucent black acrylic so the words will be difficult to distinguish when not backlit. Each mission will have a laser LED behind it (partitioned of so there's no cross contamination) controlled by the rocker switch next to the mission. If the mission's name is visible this indicates the misson has been completed.
Top/Bottom- I intend for this case to be almost entirely vertically cooled. Two 120mm fans on the bottom of the case will intake air and an exterior 92mm fan on the back along with a 120mm fan on top will exhaust it (the power supply will exhaust as well). There's a mistake in the picture of the bottom, the case will be watercooled so there should be a dual 120mm rad between the case and the fans. As shown the case will sit on MNPCTECH billet aluminum case feet. Billet handles will be mounted on the top along with an aluminum blowhole for the exhaust fan. Inside the blowhole with be another aluminum hitman logo.
Interior/Cooling- I intend to use carbon fiber vinyl on the mobo tray and powercoat the rest of the interior black. I've never watercooled before, so any suggestions here would be greatly apprieciated. To me, looks are as important as cooling. I plan to use black coolant and mount the res and pump underneath the drive bays. My tenative plan for the loop is: res→ pump→ bottom dual rad→ gpu→ 92m rad on back→ northbridge→ 120 rad under top fan→ cpu→ res.
I suppose that's about all. I don't want to be begin only to find I've made a major planning mistake, so any comment, criticisms, or suggestions would be greatly apprieciated.
Wow, I really like your concept (especially since i loved playing hitman)!
Good luck with the build, thread subscribed ;)
Hey guys.. I haven't had much of a chance to work on the case yet (school) but I did cut one of the left side windows and I figured I should post a pic just to give people a taste. I used an old scroll saw to do the window. Shown here with the trim molding I'm going to use and with the panel still taped off.
I'll try to cut the other two windows tommorrow but I don't know if I'll get a chance.
I finally got time to cut out the other two side windows. I'm going to be using that trim molding on all three. As you can see, there's still tape on the left panel because I'm about to drill the holes for the rocker switches.
I also thought I'd post pics of some of the MNPCTECH hardware that I got with the case (got it off ebay, somebody apparent started a mod and them quickly lost interest).
I've got some vents and aluminum fans too but I don't know if I'll use them.
Still trying to decide whether or not to use a barcode and, if so, where? Any ideas would be apprieciated.
More updates coming soon.
Just a small update. I drilled all the holes for the rocker switches on the left panel. All unsightly cuts will naturally be covered by molding or switches.
I'm thinking about putting the barcode on the back of the case just above the PSU. After all, it's on the back of 47's head.
Modding finally resumed this Thursday night. I mounted the handles and blowhole on the top panel. I have to say, MNPCTECH makes some awesome bling.
Eventually, the panel will be powder coated chrome black and the handles and blowhole will be red.
As you can see, there are a few errant holes left by the previous owner of this case. I'll fill those in with some high temp JB weld (supposedly compatible with powder coating) after I go to the hardware store in the morning.
My goal for tomorrow is the completion of the front bezel.
Sorry for the long time between updates. Most of the work I've been doing has been important, just not glamorous enough to post. I've been filling in a lot of holes, sanding, cleaning, etc.
Here's a pic of the aluminum trim I made for the front bezel. Still got about an hour of filling and sanding to go before it's perfect.
The trim will eventually be powder coated red.
I'm agonizing over whether or not I want to powder coat my panel. I really want the great finish, but I'm worried about outgassing from the JB Weld I used to fill in several holes. It might be safer to just paint the panels or use vinyl film.
Any input would be greatly appreciated.
I had some setbacks today (most notably my dremel dying in a fiery ball of ciruit-breaking electricity) but I still managed to make some progress on the front panel. I extended the drive bay holes all the way to the bottom and drilled some holes to screw on the aluminum trim. Here's some pics of the progress. I apologize for the glare, the flash on my $40 camera does not do well with shiny metal.
The empty areas outside the blowhole will be filled with round hole modders mesh and the area inside will be red acrylic.
Thanks for the enthusiasm 9mmx19
I finally got time last night to start working again. Deciding it was time to get to work on the chassis itself, I cut out the fan holes for the two bottom fans.
Marked and ready for cutting
Fan holes cut
I'm currently working on filling in some holes in the bottom of the case. I'll probably cover the cuts with U-channel if I can find some big enough.
More updates coming soon. It's paint time!
Thanks for the enthusiasm craigbru and officermartinez.
The painting has begun! I'm still sanding and cutting some pieces, so not everything's getting painted at once, but I have made quite a bit of progress. I'll let the pictures do the talking.
All items were primed and then the top and right panel were painted with metallic black while the blowholes, handles, switches, and fan controller were painted with gloss red. I'm going to let everything cure for a week and then wetsand and clearcoat. I'm also going to paint the nubs of the handles black.
As always, comments and suggestions are appreciated.
Unfortunately, this weekend has been very busy and I havn't had much time to work. I finally got a couple free minutes tonight but I didn't get very much done. The painting is going slowly, but that's okay, it leaves me more time to save up for the goodies inside the case :D .
During the week I managed to get the nubs of the handle painted black. They still need to be wetsanded and cleared, but I think they already look really cool. Here's a brief recap of their progression.
The "stock handles," already so nice and shiny.
Painted entirely red (sorry, massively cropped picture)
Painted red with black nubs (current state)
