Hisense H9F - $549
mrpickem
Hisense is the best available budget TV imho. The Hisense is better than comparable Samsung and Sony in the $800 to $1,100 range. The TCL R625 is pretty close but the Hisense is better in motion handling, has a wider color gamut and is the only 120Htz panel in this pricing segment. The colors are more saturated than authenic, but gives that wow pop when first viewed. Basically the only weak points are black levels do struggle a bit and the IO is a bit sluggish. The Android OS covers lots of options but does lag in actual use.
Currently at Best Buy:
55" H9F is $549 ($50 off)
65" H9F is $799 ($100 off)
