hight temps nonoverclocked. advise?
bschultz
Specs are in my sig.
Idle at around 36c
I'm using Intel Thermal Analysis Tool and under full load I'm getting temps of 57c with nothing overclocked. all stock.
in orthos i get 52c
things I have checked so far are... Made sure all fans are running at full speed, and I also took off the cpu heatsink and cleaned off the cpu and the cooler and reapplied AS ceramique. nothing changed.
You can see from my sig the case I have and my cpu cooler an XP-90. The fan is a 92mm Panaflo M1A (the medium speed one) I was hoping to have better temps then this. I get these temps and I'm not even overclocked yet. :(
AS Ceramique has a burn in time located on the instructions or online. It takes many hours of both warm ups and cool downs (turn off your computer at night) before lower temperatures are achieved. I am not sure how much lower you will go after the correct number of hours, but it should make a difference at least. More info probably available on their website.
I don't want to make any recommendations for anything other than that right now, not unless some of the other more experienced users don't post.
