HighSpeed Projector? (200hz!)
fat-tony
Hi!
I'm working in a research lab for the summer, and we're looking to get a very fast projector (LCD/DLP presumably). I admit I don't know a whole lot about the technology used in them.
I found a Sharp projector that claims to have a max vertical refresh rate of 200hz. Would it be actually updating the image 200 times/sec, or will it be interpolating? Is there even a projector in existance that will do actual 200hz?
I've looked around all morning, but haven't come up with any good answers :(
Thats probably the speed of the color wheel, since its DLP. so its actually 200hz/3colors or 4 if it has a black/white spot on the wheel as many do.
The fastest dlp projector i've seen at a reasonable price is the infocus depthQ, its used for stereoscopic projection (page flipping) hence needs a fast refresh rate to avoid flicker. It goes at around 120hz compared to the normal 60hz for most conventional dlps (although you can get some that go to 85hz).
