Highpoint RocketRaid2220 - Broken Raid
Hello all. I wanted to know if anyone had any experience with HighPoint RocketRaid2220 card. I recently used it with 8.pcs. Seagate ST3500320AS HDDs and was using RAID 1/0.
One disk is now degraded and after system restart no data is visible on any of the HDDs, they seem to be empty/formatted (with no file system, but they had NTFS before and all data was visible)
BIOS on RAID card seems OK except for one Degraded disk but in Windows the Highpoint RAID Management Console shows two "RAID10_0" arrays with status Disabled (before there was one array working with status Enabled. When the console is started is says "Raid checking" - The following arrays can not be used, do you want to delete them?
Does anyone know if there is any way to get back the data and/or restore the RAID?
Operating system that I used was Windows XP Professional SP3.
With the help of the Support staff at HighPoint I was able to delete the Arrays, create a new array and the data was visible :)
